Subframe
Subframe
I have a 67 camaro that i need a sub frame for. I found a 70's model camaro don't exactly know the year. It has a subframe but the steering box is farther forward. Could i use this subframe if i modify my column.
RE: Subframe
ORIGINAL: Matts01ES
why dont u go get the complete subframe kit with the tubular arms and coilover?
I got a couple of 69 subframes, with disc brakes for $500-750
RE: Subframe
not always my friend. a stock subframe is not a big money item (or at least it shouldn't be). as long as you know what to look for, as with any used parts, there are good deals out there to be had. one of the subs I found even had all new poly busings installed
