Starter Wire
Old Apr 1, 2008 | 11:17 AM
1977Camaro350's Avatar
Default Starter Wire
Trying to figure out where a wire goes. Its a short one comes out on the passenger side of the block on the back ofthe block and itintersects with the 2 red wires coming from the alternator andthe small wire that is on the same post on the starter as the positive battery cable. When I had the battery hooked up it touchedthe valve cover and shorted out (with the ignition off)itself and thesmall wire that connects to the same post on the starter as the positive battery cable (one of the ones it intersects with). It had abig black plastic clip on it. I think its what is keeping the engine from turning over.
Old Apr 2, 2008 | 11:55 AM
1969 SS's Avatar
Default RE: Starter Wire
what color is it?
Old Apr 2, 2008 | 12:03 PM
Red
Old Apr 2, 2008 | 12:40 PM
1969 SS's Avatar
the red wire should be on the same post as your positive as your battery cable. there should be another wire (possibly purple?) that should go to the "S" terminal on the selenoid
I am kind of confused by your original post though?
Old Apr 2, 2008 | 02:42 PM
The wire that im trying to figure out where it goes touched he valve cover and shorted itself and the small red wire that goes on the same post as the positive battery cable.
NorthernCrew454
Aug 20, 2011 07:14 PM
9434V6
Aug 19, 2011 08:52 AM
RatCamaro
Jan 29, 2011 08:55 AM
hshawn31
Jan 13, 2008 02:45 AM
twankieman91
Dec 19, 2007 06:46 AM
