Sport Coupe
Old 11-01-2006 | 05:25 PM
81CanuckZ's Avatar
Default RE: Sport Coupe
The head numbers only work if they are the original heads for that engine. I should have pointed that out. : P
Old 11-01-2006 | 07:43 PM
Andross's Avatar
I couldnt find the number...
how easy would it be to see if it is still inside the car?
Old 11-02-2006 | 02:06 AM
81CanuckZ's Avatar
Not very. If you know if the heads are original you could check the head numbers. That would be the easiest. There's a good chance that the block number's all covered in grease and dirt and isn't visible...
Old 11-03-2006 | 04:22 AM
v8chvyguy's Avatar
Okay, I'm getting aggravated, If the sport coupe code is Q, and the sport coupe is not a Z28, as you say, then what is the code for the Z28? Don't tell me that it's the S code because that was the code for the Type LT and later on the Berlinetta. and GM lists no other codes. 1Q87 was the only prefix I have ever seen on all the second gen Z28's I've ever looked at, including the 79 Z28 I own. Just so you know I also own a 79 Berlinetta and the prefix on that car is 1S87. The RS and Z28 are cosidered sport coupes and carry the Q code. If you motor is a stock and untouched 350 then you should find either 186, 624, or maybe 882 heads bolted on it. In 79 the fifth charactor was the engine code L was the 350 and G was the 305 which usually came with the 2bbl carb. alot of guys did 4 bbl converstions to these motors.
Old 11-03-2006 | 01:37 PM
Andross's Avatar
Well Mine has got a 4bbl on it... I know that doesn't mean much so Ill go check out the VIN code a little later I'll check the VIN later today. Lets hope I get an L!!
Old 11-03-2006 | 10:08 PM
Andross's Avatar
Checked it out... seems like it is only a 305 how disappointing...
Old 11-18-2006 | 09:31 PM
kanediggity's Avatar
so what does it need to say to be a Z-28 im kind of confused lol.
Old 11-21-2006 | 04:24 AM
v8chvyguy's Avatar
I think it is somewhere on the data plate, but, I can't find much info on it. My Z and my RS both have the 1Q87 prefix but only the Z has the black trim and headlight bezels, it also has a thicker front sway bar and came with the five spoke steel rims wraped in 225/70R15's.
slayer13x
09-22-2013 06:43 PM
80Mike
02-01-2012 01:14 PM
chevydrvr
04-29-2009 11:06 PM
Kammerpal
01-10-2007 01:34 AM
Quick Reply: Sport Coupe
