Sport Coupe
Old 10-31-2006, 12:43 PM
Andross's Avatar
Default Sport Coupe
I looked up the Vin Codes online for my 79 and it shows that the second dig is a Q... Q=Sport Coupe... What's this mean?
Old 10-31-2006, 12:59 PM
bowtieguy's Avatar
July 2009 ROTM
Default RE: Sport Coupe
it means it is not a z-28.its just your standard camaro,nothing fancy, nothing flashy.you can make it what ever you want,you just have to upgrade a couple of things
Old 10-31-2006, 01:01 PM
Andross's Avatar
Thanks. I thought so.
Old 10-31-2006, 02:38 PM
Andross's Avatar
Does that mean its a 305 or could it still have a 350?
Old 10-31-2006, 03:58 PM
bowtieguy's Avatar
July 2009 ROTM
my car is a 78 sport coupe and it had a 350 in it.
Old 10-31-2006, 08:21 PM
Andross's Avatar
Is there a way to tell the Diffrence between a 305 and a 350?
Old 11-01-2006, 01:52 AM
bowtieguy's Avatar
July 2009 ROTM
not sure if there is a visual difference but you could look the block number up at www.mortec.com
Old 11-01-2006, 02:40 AM
81CanuckZ's Avatar
The number on the heads would be easier. MUCH easier to find. Just pull off a valve cover and the number should be stamped right there.
Old 11-01-2006, 02:44 AM
bowtieguy's Avatar
July 2009 ROTM
thats true but you dont know if someone has had to replace the heads.they could have put 350 heads on a 305 or vise versa.get the block# off the back of of the block where the bell housing bolts up on the drivers side.
Old 11-01-2006, 01:32 PM
Andross's Avatar
cool thanks. ill look it up.
cross your fingers! lets hope its a 350
Quick Reply: Sport Coupe
