Some black spark plugs
Old Jul 26, 2012 | 12:00 AM
mikeestheman's Avatar
Default Some black spark plugs
I have a 70 camaro with a 350. I have a new intake, 4 barrel carburetor (that I have jetted down to 58), and headmen headers. I have been having real bad gas mileage so I checked my spark plugs. I noticed that they range from being tan to black and everything in between. What would cause some to be black and some not?
Old Jul 26, 2012 | 12:45 AM
Bad valve guides or bad rings allowing oil into the combustion chamber. 58 is low but I have seen 62 on a mild 350 with a 600 Holley. Do a compression check to test the ring seal. I would look for even numbers cylinder to cylinder instead of how much pressure its building.
Your driving a 70 Camaro what do you think good gas mileage would be? Keep your foot out of the carb that is the only way. Then its a trip to overdrive city if you want to knock down modest numbers.
Old Jul 26, 2012 | 10:11 AM
Good gas mileage for a 350 with a 1-1 trans output, and something around 3.50-3.73 gears is probably still not gonna be more than 17mpg on the hiway at 60mph, IF you don't hit it hard. Around town most of us will drop 4-5 mpg with start and stop driving, and the lead foot problem.
I am getting nearly 17 mpg on the freeway with twin 450 Holleys on a tunnel ram at 6- mph, but around town I tend to be hard on the throttle. My plugs always show a bit dark when I check them, unless I just get off the freeway and check them.
Old Jul 26, 2012 | 01:06 PM
Val's gotta show that thing off around town. SOB will pass everthing on the street except a gas station. God I want a ride.
Old Jul 26, 2012 | 02:16 PM
They look more gas fouled then oil fouled but I will still do a compression test.
Old Jul 26, 2012 | 05:00 PM
Check your timing. Can't imagine with the carb and smaller jets you'd be running rich with proper timing, unless you've maybe got a bad power valve.
Knightrider03m
Mar 20, 2011 11:57 PM
sebi1990
Oct 10, 2010 10:24 PM
countryboy
Mar 15, 2007 12:39 AM
zioneffect564
Oct 18, 2006 04:51 PM
