should i use these headers?
Old Nov 2, 2008 | 09:23 AM
camarohead's Avatar
Default should i use these headers?
I've got a set of flow-tech headers. The flange that bolts to the heads are oval. i know they should be square but the oval is bigger than the diameter of the exhaust port on the heads. I know these will fit and work but should i use them? will there be and power loss or gain with these compaired to a square flange? thanks
Old Nov 2, 2008 | 03:03 PM
Default RE: should i use these headers?
As long as the opening on the header flange is bigger than the ports of the head, it will be fine. You won't lose or gain anything. Now, if the header flanges were smaller than the head ports, you would be restricting/obstructing flow.
primo_1976lt
70-81 V8 Tech
Sep 2, 2010 01:52 PM
broncojr_8907
Jun 19, 2010 03:48 AM
sPaC31
Jan 14, 2008 06:43 PM
myTreadZz
Oct 31, 2007 10:24 PM
2fast4u
Jun 4, 2007 08:34 PM
