Shifter issue
Old Dec 28, 2011 | 02:52 AM
RamzaFreak20's Avatar
Default Shifter issue
Can anyone give me some advice? I have a 4 speeds shifter I just took off my car that is stuck. No, it is not attached to my transmission. I've soaked it in carb cleaner, hoping it was a gunk issue, but no progress. I'm just trying not to buy a new shifter, since it is right after Christmas and I am low on funds.
Thanks,
Jon
Old Dec 28, 2011 | 06:10 AM
rydeer's Avatar
post a pic of the guts. Something must be bent or broken.
Old Dec 28, 2011 | 12:03 PM
Could be the bushings are so worn it's hung up between gears. SHould be able to align the arms and get a neutral position to put the alignment pin in. Then check play in all the rods and arms to see where the issues are.
Old Dec 28, 2011 | 05:34 PM
Was taking pictures of the shifter when I noticed the flat part of the shifter stick was in the way of the 3rd-4th shifter lever. I'm not sure what happened, but I had to pull up like I was putting it in reverse, then had to realign everything. Almost like a dislocated finger.
Thanks for the responses, too.
vXIcetreyXv
Feb 11, 2011 12:43 AM
DIPSTICK_JIMMY
Sep 24, 2009 08:00 PM
gozzy341
Aug 9, 2007 01:40 PM
creed777
82-92 V8 Tech
Mar 30, 2007 03:07 AM
Don Hog
Oct 30, 2005 02:35 AM
