shift kit
shift kit
my car. has a very steep shift kit in it. its built for the track. is it very hard to do a shift kit. i dont know alot about automatic transmissions. how hard is it to change the shift kit for a more street set up car????
RE: shift kit
I don't think its that hard to change back to a milder shift kit. Drop the tranny pan and change a few things out, then button it back up and fill the tranny again. (Get a new gasket for the pan.)
I suppose it has a big stall converter in it too? If so,you will need more work to fix.
RE: shift kit
ORIGINAL: thebandit110
should i just drop the tranny and rebuild it??? or just change the stall setting and the shift kit???
The stall converter, depending on which one it is, will get up to a certain RPM before it locks up. (It will still move the car at lower RPM.)
This usually has the car shifting 'softer', and adding a shift kit in makes it shift harder.
So depending on what you want it to shift like, I guess its your call......
apetsel
03-25-2011 06:27 PM
