Restore Steps
Nice...thats good to know. My tie rod broke on my last Camaro so that is a good idea to check.
So would a 78 or 80 pass a state inspection being original? or are there modifications that need to be made to pass inspections?
Wiggling the front tires can be worn ball joints or tie rod ends, but then again if you're not having someone wiggle while you look, it could be as simple as a poorly adjusted wheel bearing, or worn wheel bearing.
Forget the rag joint. Even if it's bad it's simple and cheap to fix. Rust is the worst thing to find, and most common, and unfortunately hardest to spot! Make sure to take a floor jack with you and if the seller wont let you jack it up and check for floor pans rusting out, then don't buy it.
The one in the picture looks like it could be a decent buy, but you wont know until you get under it and poke around with a screwdriver to see if it goes through the floor. If it's not too badly rusted I'd grab it at that price, especially with a decent engine and trans.
What do you guys think about this one?
1978 CHEVY CAMARO!!
I offered him $2,000 and he said he would take $2,400...is that a good price?
I havent seen the car but he said there is no rust, everything is original, but it needs rod bearings.....? HE said you can drive it but when your heavy on the gas you can hear the bearings knocking....what do you think?
1978 CHEVY CAMARO!!
As for the other car at $2400, it's a good looking car, but no way to know without seeing it good. You'll have to decide if it's solid. I'm surprised the seller would even consider an offer over the phone without you even looking at it. Sounds like he's desperate.
One other thing; don't buy a car that's not complete body and interior. If the engine or trans is gone it's no big deal, but if it's missing a bunch of interior or exterior trim it will kill your budget finding all the little parts. Some of those parts are impossible to find for later 2nd gens too!
If you have to ask, then it's probably going to be a hard job for you. The engine needs to come out of the car to change rod bearings, but if it needs rod bearings then it also needs main bearings, and there's no sense in stopping there. Once you've torn into the bottom end of an engine you should totally rebuild it, which will run several hundred dollars in parts, and probably $600 in machine shop charges, and then you need to know how to assemble it correctly yourself, or pay a shop to do it all at around $1200-$1300 for an average build.
