Removing Coil Springs
Old Apr 11, 2010 | 06:46 PM
1977Camaro350's Avatar
Default Removing Coil Springs
I'm trying to replace the ball joints and worn out control arm bushings in my 77. I bought the compressor for the coil springs but I cannot get it to stay on the spring when I'm compressing it. I thought I had all the tension off the spring but when I took the nut off the lower ball joint to take the lower control arm off the spindle there was still a lot of tension on the spring and didn't realize it would extend so much so the control arm separated from the spindle but the spring is still in there but I still can't get it out
The compressor keeps popping of and the spring just pops back into place. All of the arms of the compressor are seated nicely and I can start compressing it and can compress it about an inch or so before it comes flying off.
What the heck am I doing wrong here?
Old Apr 11, 2010 | 08:28 PM
Do you have a good compressor, and are you trying to compress the whole spring? You need to just compress about 2/3 or so of the spring. That will be enough to allow it to come out. If you try to do more they can pop off and hurt you or break something.
Old Apr 12, 2010 | 05:49 PM
It's a Blue Point Compressor from Snap-On. I tried to get as much of the spring as I could with the compressor.
I will try and not compress so much of it
Thanks.
Old Apr 12, 2010 | 07:49 PM
Well you've got a great compressor, so hopefully a smaller purchase on the spring will get it done.
mainejohn
Mar 18, 2011 07:05 PM
sawyermgmy
70-81 V8 Tech
Jan 30, 2011 10:58 AM
kudnu89
Jan 5, 2011 09:42 PM
BasicConcepts
Sep 14, 2010 04:52 PM
jenz
67-69 V8 Tech
Dec 27, 2009 11:15 AM
