rear diff housing
Old 04-03-2011, 12:48 AM
I know. Just sayin. 10 bolts got a bad reputation for some reason.
Old 04-03-2011, 08:56 AM
gfrench's Avatar
There are lots of 10sec cars running 10 bolts. They just replace the axles and c-clip eliminators.
Old 04-03-2011, 09:46 AM
I've broken a couple 10 bolts when I was racing the '71, but once I went through the present one and got everything dialed in I've never had another problem. The 10 bolt in my Camaro has been in there since 1982.
I put a pair of Dutchcmans axles in it, C clip eliminator kit, and PowerTrax locker. New gears, but can't remember now what brand they are. After all the changes it's been indestructable, even when the slicks really hooked up. Of course I only raced it for 7 yrs. after the rework, but that's enough to know it works well behind my 427.
Old 04-05-2011, 10:42 AM
Johns79 Z/28's Avatar
thank you...also this is the "code" stamped on the axle (1 F G278 1) passenger front side but, it doesn't match up with anything I have found associated with a 79 camaro...so I suspect that it isn't original, even though it "looks" stock...any Ideas?
Old 04-05-2011, 04:38 PM
The F indicates it's from a Camaro. The G indicates it's from Detroit Gear, the assembly plant. Not sure on the numbers, but maybe the 78 indicates 1978??
Old 04-06-2011, 02:24 AM
Which sounds logical, they stockpile parts before production begins.
Old 04-06-2011, 12:49 PM
Camaro
I was under the
impression
that (278) was the day of the year it was made...but that
doesnt
help me find what the gear ratio is
Old 04-06-2011, 06:31 PM
Originally Posted by Johns79 Z/28
I was under the
impression
doesnt
Got no idea if 278 is the day of the yearr. I'd be surprised if they got that exacting. To find the gear ratio just pop the cover and count ring gear and pinion gear. Then divide the ring gear number into the pinion. Or jack it up and see if it's posi or not. If it's posi you can mark the tire and see how many turns the driveline makes with one turn of the tire. That's your ratio. If it's not posi then leave one wheel on the ground and do it, then double that to get your ratio.
YAV8
08-30-2014 10:52 PM
richard.nelson100
12-11-2011 05:25 PM
richard.nelson100
12-10-2011 05:38 PM
68ssap
08-04-2007 04:14 PM
Quick Reply: rear diff housing
