rear brake question
Old Feb 26, 2008 | 07:58 PM
nuttyprofessor's Avatar
Default rear brake question
got a rear end with disc brakes out of an 81 turbo T/A (wish i kept that car) and want to stick it into my 81 camaro. I know it will bolt right in, but will the original master cylinder work in the camaro work? I am assuming that I will need to get the master cylinder from a turbo t/a or at least the proportioning valve so the brakes will work right. Anyone have any input?
Also, can anyone tell me what the specs were on a turba t/a rear end?
Old Feb 26, 2008 | 10:10 PM
JRs72RS's Avatar
February 2009 ROTM
Default RE: rear brake question
Original master should work fine. Instead of buying a complete prop valve, just get an adjustable
Wilwood and install on your rear line. It is cheaper and easy to set for correct bias.
jp 71 camaro
Nov 7, 2010 08:36 PM
Revolator
Aug 14, 2010 12:16 PM
GSchubes
Apr 10, 2010 08:41 PM
69camarokid
Nov 10, 2006 12:55 PM
sewerrat
Dec 8, 2005 02:24 AM
