Quick question for a Guru or someone with a service manual...
Old Apr 1, 2008 | 06:47 AM
High PSI's Avatar
Default Quick question for a Guru or someone with a service manual...
Hi all,
Wondering if anyone here could tell me what the preload should be on the front wheel bearings on a 2nd gen? If anyone has a factory service manual and wouldn't mind looking it up for me I would greatly appreciate it.
Thanks,
-Mike
Old Apr 1, 2008 | 06:52 PM
Default RE: Quick question for a Guru or someone with a service manual...
Spin the hub forward while tightening to 12 ft-lb. Give wheel a few turns forward. Back nut off & repeat frst step. Back nut off & tighten by hand ( no wrench) until snug. If the slit in the nut does not align with the hole in the spindle, back off nut slightly until the hole aligns with the next slit. Insert cotter pin.
Old Apr 1, 2008 | 08:38 PM
High PSI's Avatar
Thanks for the quick reply Pete! Just what I needed.
nj85z28
Nov 27, 2011 12:42 AM
cmrz
Feb 25, 2007 11:10 PM
mahfish
Apr 24, 2006 09:39 PM
