overheating issues
Old Sep 16, 2010 | 12:28 PM
Bjm3.8's Avatar
Is the stock radiator just a one row radiator?
Old Sep 16, 2010 | 03:32 PM
80ZJoe's Avatar
July 2010 ROTM
I don't think the Z28's came with the little rad, only for the 267's or the 305's
Old Sep 16, 2010 | 05:46 PM
Bjm3.8's Avatar
Do you know what they were vy any chance? I've found a direct fit 3row and I was hoping that was better than stock
Old Sep 17, 2010 | 05:26 PM
I believe the Z28 was a 3 row, so I'd go with either a 4 row or two 1" rows.
Old Sep 17, 2010 | 07:35 PM
80ZJoe's Avatar
July 2010 ROTM
Yeah my 78 Z has a 3 row (stock), it should work pretty good if everything else is working good (fan, shroud etc.) maybe get a extension for your fan so it can be closer to the rad? but to be on the safe side i would just look for a bigger one.
Old Sep 20, 2010 | 08:19 PM
thebandit110's Avatar
BB427 would you happen to know the part number to your rad???
Old Sep 20, 2010 | 08:37 PM
80ZJoe's Avatar
July 2010 ROTM
^^ not sure what his is but heres a couple links from Jegs that are dual 1" core alluminum.
Manual
http://www.jegs.com/i/Be+Cool+Radiat...60010/10002/-1
Auto
http://www.jegs.com/i/Be+Cool+Radiat...62010/10002/-1
Old Sep 22, 2010 | 11:11 AM
Bjm3.8's Avatar
Sorry its been a while since i've posted about this problem but, the car is still overheating. I put a 160degree thermostate in and it still over heats with the same symptoms. i figured the thermostate wouldn't help but for $13 is was worth a try. I know the fan isn't stock thats on the car, i don't even think it's the stock 18in size, it's a lot smaller. So i went to the parts store and picked up a stock 18in fan for $20. I noticed that diagram said the fan needs to be 1in from the back of the radiator. Well i measure and it was pretty obvious it wasn't even close. Currently there is a 5.5in gap from the back of the radiator to the front of the fan. I know they make spacers and the biggest one i've found is 3in which still doesn't put me close enough. Plus i believe there already is a spacer on the current fan, so i'm stuck. I'll tear into it all this weekend but i'm baffeled as to how i'm going to solve this issue.
Old Sep 22, 2010 | 05:34 PM
Toss us a pic or two.
Old Sep 22, 2010 | 06:57 PM
  #20
Bjm3.8's Avatar
