No Spark???
I got a 81 Z with a 305. I recently had a EZ Wiring harness put in. I bought new wires, plugs, and refreshed everything in the engine. I bought a new battery and got rid of the old side post one. My problem is im Not getting any spark. She'll sit there and crank forever but never any luck...
Based on what ive told you what could my problem be?
If you need to know any more information on my setup ill let ya know...
Thanks guys
Thanks guys
Did the car start before the wiring harness was installed? was there a period of time between when the harness was installed and before you did the plugs and wires when the car started? Also what does freshen everything up in the engine mean?
Start with the basics. Check to see if you've got 12v. going to the coil and that it's properly grounded. Then check electrical connections are right to the coil.
I paid $600 for them to hook everything in. I checked the wires in the HEI and have double checked my firing order. Ive been trying to tie down the guy to come out to my house to look at it considering he works in my small town about 4 min away
And I just meant that I replaced gaskets and thermostat and all...nothing to do with my issue...just giving more info lol
