Mixture screw missing
Your missing a screw and the one in the middle is either a screw hole for the choke braket or the vacuum port for the choke. If its the port it needs to be blocked. To me it looks like the braket behind the choke lever is not on correctly.( slightly tilted upward in the rear
Are you saying the screws are missing, or the holes aren't even drilled and tapped? I've never seen a double pumper that didn't have metering block mixture screws.
It isn't my carb, it belongs to a friend in another forum.
I had him use a mirror and said he could not see any threads.
Also took one of the screws out of the front and they would not fit.
Sounds like a defect. If it's a double pumper it should have a metering block, and if it has one it should have adjusting screws. On single pumpers they don't even put a metering block on the secondary bowl, regardless of whether it's a dual feed or single feed.
It is like 30 years old, so probably not defective.
Im thinking leave it alone, until he is ready to get a new carb.
I wish it was here, I would just pull the metering block off and look at it.
zeppelin
82-92 V8 Tech
Jul 18, 2006 04:14 AM
