Master Cylinder
Master Cylinder
We are adding rear disk brakes to my sons 79 Camaro. Any recommendations on master cylinder for this new disk/disk set-up? It currently has the original disk/drum master cylinder and booster. Also any recommendations on the proportioning valve.
Did you use the rear disk brakes off a 2nd gen Z28? If so just grab stock parts. If not you will need an adjustable proportionate valve.
