losing spark why?
Old Jul 25, 2010 | 01:22 PM
tokinkenny's Avatar
Default losing spark why?
Ok so i recently bought a 81 z28 the car will start and run for a little bit then just shuts off almost like u shut the key off. I have been able to crank it after it dies and check for spark and im gettin nothin but after it sits for ten fifteen minutes it will start back up and run its only stayin runnin for 5 to 25 seconds i have replaced the coil the dist cap and rotor what could be my issue also it never loses power to the coil so i know its not a bad ignition switch
Old Jul 25, 2010 | 02:12 PM
might try an ignition modual.
Old Jul 25, 2010 | 08:03 PM
rosky69's Avatar
I'd start looking for a short. Maybe the vibration of the motor is causing one of your wires (with thinned out insulation) touch something metal. Just a thought.
Old Jul 25, 2010 | 10:13 PM
80ZJoe's Avatar
July 2010 ROTM
Both the above thoughts i would try out, by any chance do you prime the carb before starting it every time? could be your fuel pump if thats the case?
Soundwave
Jul 22, 2010 09:29 AM
IZZY1967RS
Feb 26, 2008 11:12 PM
sl1foru
Feb 24, 2008 08:30 PM
superROB23
May 8, 2007 03:46 PM
