Looking for help on two issues
Old Dec 6, 2006 | 12:38 PM
davejmc's Avatar
Default Looking for help on two issues
First: I've been trying to track down the correct bulb for the INNER tail lights on a 1969 Camaro. I have 1157s in the outer and 1156 for reverse. 1156 for the inners are too bright and 1157's have dual contacts and do not work. Rick's First Generation lists a bulb with part no LT-16, but I was trying to cross reference the bulb. From what I can tell, the bulb has T67 and 5I or 51 markings on the bulb housing. Any help finding info on this bulb would be appreciated.
Second: I'm trying to connect the shift linkage to a th350 with console shift option. I think the car used to have a powerglide and I think someone tried
to reuse the powerglide shift cable brackets. It works except the trans pan keeps it from shifting into low gear. It's the mounting bolt on the gear selecter lever that hits the pan. I've bought the correct gear selecter lever and cable mount bracket. My problem is I'm not sure what size/length bolts to mount the cable mount bracket to the th350. The powerglide bracket used the existing trans-pan bolts, but this bracket mounts on the side.
David McMillan
Old Dec 6, 2006 | 12:49 PM
shnormo's Avatar
Default RE: Looking for help on too issues
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Old Dec 6, 2006 | 12:58 PM
davejmc's Avatar
I've been to sylvania before. They list the inner and outer as the same bulb.
David McMillan
Old Dec 6, 2006 | 01:08 PM
shnormo's Avatar
Hmmmmmmm Well can you put a resistor for the 1156? Cuz I'm stumped myself
WIspartan1026
Jun 19, 2012 04:28 PM
mick.mcgirr
Jan 3, 2011 11:23 AM
camarophil22
Feb 18, 2010 09:42 PM
red star
Aug 21, 2009 01:46 PM
laxloser18
Apr 28, 2007 09:06 AM
