Looking for a good source of basic sbc swap knowledge
Old Apr 11, 2007 | 08:22 PM
chevyman95's Avatar
Default Looking for a good source of basic sbc swap knowledge
I just recently bought a stripped out camaro and a 350 and I soon realized I have no idea what I am doing. Does anyone know of any good camaro forums or any resources I should try to look for. I know i need some wiring, and misc here and there things.
Basically im looking for a motor swap for dummies resource.
Old Apr 12, 2007 | 11:54 AM
maddog70's Avatar
Default RE: Looking for a good source of basic sbc swap knowledge
Depends on what year / type of motor you are putting in. This forum is great for questions, there are a lot of very experienced second gen camaro peoples out there.
What are you putting in? For a mid 70's 350 all you need is mounts and 12v at the distributor. The tach is even one wire. If it's a TBI or TPI, you will want the harness and computer from the donor car. There are aftermarket kits available, but $$$.
I'm not sure of a good book specific to second gen camaro, but you can find an assembly manual on ebay that may be helpful.
Old Apr 12, 2007 | 03:28 PM
chevyman95's Avatar
Late 60's and it's actually a 327 sorry for the mistype
Old Apr 13, 2007 | 01:07 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
You are putting a 327 in a first gen or a 327 into a second gen? Either way this is a good place to get knowledge. Real time answers (well, as soon as someone with the answer reads the question. There is a general tech subforum at the top of the opening page. Or you can continue the questions here and get answeres soon too. As far a motor swap for dummies, I think this is the bast place to be. So, ask away.
Old Apr 13, 2007 | 01:56 PM
MadMikeZ28's Avatar
ORIGINAL: chevyman95
"Does anyone know of any Good Camaro forums......"
What are you trying to say? We are not good?[]
Old Apr 13, 2007 | 05:12 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
maybe this will help some. https://camaroforums.com/m_4042/tm.htm
Old Apr 14, 2007 | 03:26 PM
chevyman95's Avatar
Haha no this is a great forum I had just copied and pasted my entry from another non camaro forum.
It's a 79 drag car and im putting a late 60's impala 327 and turbo 350
Old Apr 14, 2007 | 03:30 PM
Blade's Avatar
June 2007 ROTM
u need any parts for that sb?
Old Apr 14, 2007 | 03:58 PM
chevyman95's Avatar
no but I appreciate the offer blade
This is what I have so far....let me know if im wrong or missing something.
Ok so as far as I can see there are 2 large mounts for the motor. They are some kind of rubber or something. This motor is supposed to have in the neighborhood of about 400-500hp. Do I just use normal grade 8 bolts and put it in the mounts? Will the mounts hold up?
To connect the motor and transmission I need to bolt the stall converter to the flywheel then slide the bellhousing against the motor and bolt it up.
Next up is the transmission. It is a turbo 350. Someone suggested I put the motor in first then the transmission but I don't see how that would work. I can see that it would probably bolt into the crossmember but where else is it supposed to connect? I know that I have to connect a shifter, some wire for the carb, and a trans cooler to the tranny. Anything more than that? I know how to do the shifter but the other 2 I don't.
Also can I get a stock 1979 driveshaft to fit?
Thanks
Old Apr 15, 2007 | 10:50 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
You have a 327 pushing 400 to 500 HP?
