looking for the best cleaner
For cleaning engine grease off the engine and compartment area, here's a real "off the wall" product I use....Engine Degreaser.
I'll bet that's what that stuff is made for, and probably why it works so well. Who'd a thought, eh?
Whatever you use, make sure you scrape off the heavy stuff first, and it will work much better. If you simply spray and wash you'll do a lot of it before you reach the metal.
You drive a ford off the lot it is already leaking.... a frickin toyota, and 150K miles and it is spotless...go figure...
But I do get 200K plus out of every Ford truck i have owned....Ranger, and F150...
If you are degreasing a Crusttang, you will need Crustang remover...
