knocking sound on full lock
Old 09-03-2013 | 02:57 AM
stox58's Avatar
Default knocking sound on full lock
Hi,
when I have the steering on full lock, I get a knocking sound from the front on the left and right hand side. It doesn't do it every time though.
The local garage has checked it for me, but they can't find any play on anything. The wheels I have on are 15's, 7inch wide with 4inch backspace.
Please can someone inform me, what it's most likely to be.
many thanks from Luke ( 77 LT )
Old 09-03-2013 | 11:27 AM
It might be in the ball joints, tie rod ends, or idler arm. Does it do it while sitting still, or moving forward and hitting the locks?
Old 09-03-2013 | 11:43 AM
Could also be the spindle hitting the stop bolt, worn sway bar end link bushings causing metal on metal, broken sway bar links, loose lug nuts, worn wheel bearings. Kind of hard to tell from here. You'd think the guy at the local garage would have an edge over us, being able to look at it first hand.
Old 09-03-2013 | 02:09 PM
stox58's Avatar
It seems to do it more when on full lock and going on a incline / decline. The sound is from both sides, but I would say that it's further in from the wheels.
Old 02-09-2014 | 09:44 AM
stox58's Avatar
Just thought I would do a quick update on this thread, in-case it could help anyone else.
I have replaced the sway bar end links and there has been no knocking sound since!
Camaroamatuer
06-05-2010 03:02 PM
DarkrhaveN
04-15-2010 05:58 AM
Rhoshone
11-16-2008 10:09 AM
Andrew*B
02-23-2008 08:43 PM
HOTROD MOMMA
02-18-2008 05:59 PM
