-   70-81 General (https://camaroforums.com/forum/70-81-general-12/)
-   -   key igintion wiring help please (https://camaroforums.com/forum/70-81-general-12/key-igintion-wiring-help-please-76347/)
stox58 Feb 16, 2014 02:07 PM
Hi,
I'm looking at the connector plug which goes into the steering column, I assume there is one wire which sends +12vdc to the ignition key barrel and then when you turn the key, it will send the +12vdc back down a different cable which will go to the starter motor.
the connector block has the following colour wires
black
red
black
light green
blue
brown
purple
yellow
green
white
can someone please tell me which colour wires I'm looking for and which is the wire going to and from the ignition key barrel
many thanks from Luke
paperairplanes Feb 17, 2014 07:59 PM
the purple is the starter signal
stox58 Feb 20, 2014 04:05 PM
Hi,
Please can you confirm that the purple core is the 12vdc from the ignition barrel to the starter motor.
Thanks
1971BB427 Feb 21, 2014 09:28 AM
http://www.autopartsdb.net/images/pr...mg/1/14273.JPG
paperairplanes Feb 22, 2014 11:36 AM
all gm uses purple for starter signal, goes to clutch switch or neutral safety switch
77nomad Feb 22, 2014 06:33 PM
Yup. It doesnt go to the barrel either. The switch is much lower on the column. I have the entire harness in my dining room as I'm typing this. I have been pulling use less wires out.
The key pushes a rod that is hooked to the ignition switch mounted on the column. Not real hard to get to but it would go better if you were a contortionist.
77nomad Feb 22, 2014 06:35 PM
Oh! I forgot, Val can you send that diagram in a larger format? When I opened the one you posted it wasnt clear enough to read. I have all the black and white ones but man a color one is just much faster.
stox58 Feb 23, 2014 01:33 PM
I'm only looking at the connecter which is visible just before it enters into the steering coloume. So purple is 12v to the starter, but which colour is the 12v into the steering coloume?
The schematic is a little small to make anything out.
Thanks from Luke
77nomad Feb 23, 2014 02:51 PM
There are a bunch of power and grounds going into one particular plug. The lower left is the plug you want, there are red 12V constant and pink w/ black strip is a for 12v with the key on. This diagram is for a '78. Be warned my '80 has different colors in a couple locations. I couldnt tell you right off hand which ones though. The area in the left center is where they all go in to the firewall plug. The lower left is lower section of the firewall plug. It is basically cut in half horizontally. Power feeds to the dizzy, headlights, starter,wiper motor and AC all are passed to the engine compartment here. The upper half of the plug carries the gauge wires and such.:icon_present: :icon_google:
http://www.nastyz28.com/camaro/wire/78w-ip1.jpg
http://www.nastyz28.com/camaro/wire/78w-eng.jpg
Here is the wiring for a '74. ope these help. I have these on my tablet, it is just like having a diagram right there and I can zoom in on areas to see whats going on.
http://www.nastyz28.com/camaro/wire/74ip.jpg
1971BB427 Feb 23, 2014 05:59 PM
Not sure what's going on Damon. It's full screen size when I look at it here. I'll try it again:
http://www.2heeldrive.com/Chevrolet/...c2a8064d_o.jpg
