jump problems
Old 01-21-2008 | 11:18 PM
strokerboy's Avatar
Default jump problems
everytime i gas my camaro off tha line it boggs down and acts like it wants to die ...... i think its carb tuning but i need other ideas
Old 01-22-2008 | 12:07 AM
1980rscamaro619's Avatar
Default RE: jump problems
mine was like that when i first got her, i just fiddled with the carb and now she starts perfectly. Gas her a bit and turn the key, have no probs anymore.
Old 01-22-2008 | 12:32 AM
strokerboy's Avatar
it cranks fine it jus wen i want a fast take off it boggs down
Old 01-22-2008 | 12:55 AM
thebandit110's Avatar
i had the same problem with my 79. i rebuilt the carb and it went away. try letting it get hot also. mine did that also. but once it was hot. it did not do it anymore. but than i did a crate motor and an edelbrock carb. with electic choke....that was the best.
Old 01-22-2008 | 01:10 PM
johnson73801's Avatar
depending on what carb you have you might be dumping to much fuel or not getting enough. if its a double pumper are both ends getting fuel? if its a vacumm secondary are is the back not opening soon enough? also last thing how do the plugs look? also is the car cammed and if so are you leaving in the power band?
Old 01-24-2008 | 06:05 PM
got3ofem's Avatar
Agree with everyone above. Could be as simple as adjusting the carb. You may have too much carb, dumping in too much gas. Whats your eng/carb set-up? May have a piece of crap stuck in the fuel filter, or fuel line. People dont check that very often. Also may want to look at your fuel pump. They are fairly cheap to replace depending on your engine, and dont always just go bad and stop completely. The bandit 110 mentioned his edelbrock carb, w/the thunder AVS, you can easily set when the secondaries open.
Old 01-25-2008 | 10:42 AM
1969 SS's Avatar
you need to tune your carb, first and foremost, and then check for other problems after that. a lot of times it's an undersized accelerator pump if it's just a bog off the line
start with the tune though
RacerAV
03-29-2009 12:49 PM
94 z28
02-18-2008 07:20 PM
joeyninetoes
02-23-2007 07:50 PM
