installing equus gauges in stock bezel- pics inside
The only thing you did to the speedo was pop off the trim ring? That ring didn't hold two halves of the speedo case together did it? Although I don't know what that would have done. And, the speedo is strictly a mechanical drive (internally), not a mechanical/electro drive?
yea the trim ring just pops off, it was holding the glass only, and it is mechanical only, no hot or neg wires going to speedo, just 2 light bulbs.
i made sure not to touch the needle or anything.
Could I ask you which wires you spliced into for the illumination on the new gauges? I'm almost ready to install my cluster with a couple new gauges and just wondered if you knew the wire color in the factory harness for illumination? Should I splice into the harness on the headlight switch or the harness that goes into the cluster?
for the illumination (backlit) lights, i actually tapped into the hot wire coming off the light bulb for the wiper switch, was just easier at the time i did it, but i found this link that tells you what each wire does
Webshots - Full Size Photo
so number 5, grey wire should work.
I really appreciate the diagram, that'll help a lot! I only installed 2 new gauges (1 mechanical) and keeping the rest factory with some new faces. Don't have a whole lot of wiring to do on this but wanted to get onto the appropriate wires in the harness to do it right. Awesome job on yours, thanks again!
Sassy8722
09-14-2006 03:46 PM
