installing equus gauges in stock bezel- pics inside
Old Apr 1, 2012 | 11:54 PM
mike6208's Avatar
Default installing equus gauges in stock bezel- pics inside
when i got my 78 a couple of gauges didn't work so i decided to get some equus gauges and fit them into the stock bezel. thought i'd make a small walkthrough incase anyone has the same gauges and wanted to try it.
painted it silver to match some of the interior and painted the trim black
i then removed the trim from the gauges
using a screw driver to pry up the trim alittle, and it pops off
glued the glass from the gauge to the front of the bezel
and used a hot glue gun to attach the gauge to the rear of the bezel
completed
the speedo and rpm gauge were alittle tricky, the stock bezel was alittle small to fit the gauges snug, so i took alittle heat to it and stretched plastic for fitment.
Old Apr 2, 2012 | 12:16 AM
Nice work, looks pretty slick!
Old Apr 2, 2012 | 04:11 AM
5time F's Avatar
I like that a bunch... That is what I am planning to do too....
Old Apr 3, 2012 | 05:32 PM
mike6208's Avatar
Question for you guys that worked with Equus gauges or similar, before I took the dash apart my equus speedo worked fine, after I put it all together again, speedo Is off by 20mph, any ideas to why?
Old Apr 3, 2012 | 06:11 PM
HardTOPJoe's Avatar
Is it a mechanical gauge or electric?
Old Apr 3, 2012 | 07:04 PM
mike6208's Avatar
Mechanical, bought a speedo cable from autozone, worked before, now off
Old Apr 3, 2012 | 07:12 PM
HardTOPJoe's Avatar
The only thing I can think of is maybe the cable is in a bind or not seated in the back of the speedo fully. Do you have any hard bends in it?
Old Apr 8, 2012 | 06:09 PM
mike6208's Avatar
i don't see any hard bends in the cable, i took the cable out and put it back in the car, but its still off by 10 to 20 mph
Old Apr 8, 2012 | 08:23 PM
There wasn't a ratio adapter on the end of the old cable at the trans, was there? You would have noticed, but I still had to ask.
With mechanical drive, it now being off where it wasn't before doesn't make sense. And if the cable was binding, your needle would be jumping like crazy.
Old Apr 8, 2012 | 08:50 PM
mike6208's Avatar
i'm stumped too, it was actually reading fine before i tore apart the dash to fix the bezel up, i even drove past one of those radar things they have near schools before and it was reading fine, now if i'm driving 40 it will read about 20-25, ill just have to check the cable again or pick up a new one. i'm sure there is no damage to the speedo
