I am Looking to buy Richmond 3.90 gears and posi unit
I have a offer to trade my dart iron eagle heads 2.02 64cc straight up for a used set of 4.11 GM gears and a GM posi The rear was originally in a 91 Camaro does anyone know if these will fit my 81 Camaro? The heads are brand new still have the tape only thing one valve on the top some how got a little bit of rust my buddy looked at it and said it was fine. Any help if these will fit here is the link to the gears and rear.
http://s48.photobucket.com/albums/f216/kcnmoo/gears/
RE: I am Looking to buy Richmond 3.90 gears and posi unit
Personally, Id keep the heads (unless you dont want them) and buy a new posi unit and gears, and a master bearing set, then you wouldnt need to be concerned about if the rear partsare interchangeable- and youd have new parts(with a warranty to boot). Howd you do at the track?
I am going to stick with the aluminum heads and the track I span half the track had to hit the brakes single tire fire lol I need a posi and tires bad
ORIGINAL: got3ofem
parts
we also have the following for Sale: rearends a 10 bolt non posi 8 1/2 inch ring & pinion out of second generation camaro, 1974 nova rearend fits first generation camaro. Asking 100 a piece. Ring and pinion gears, 3.90 and 4.10 ring and pinion, 100 dollars each. Richmond posi unit 300 dollars. Willing to sell a package deal of 400 for the all the ring and pinions and unit. Or 600 dollars for everything. Call 712-215-2194
Rear end for a 3rd gen will not fit under a 2nd gen without mods, and even then it will be the wrong width. Gears and posi for the two rearends also will not interchange. You'll need a whole carrier, posi, and gears to change to this setup for your 2nd gen.
