? how much HP will a 68 10 bolt take
Have a 1968 rs with a 10 bolt. I would like to go to 373 gears with a possi.
Car now has a 327 and t350 With goodstreet tires on it. And will keep only street tires on it.
I was told not to put any money in to a 10 bolt but to get a 12 bolt. When a 10 bolt brakes bad things happen to the car? Others tell me a 10 bolt is OK. Long term I would like to get a 383 stoker installed. ? should I spend $ on the 10 bolt or go to the 12 bolt. Looks to be $2500 difference. Ya and nay Come from Strange DTS & Mossler
I know this has been cover a lot but $800 vs $2500 is a lot of cash that can go else where.
RE: ? how much HP will a 68 10 bolt take
There are a few 10 bolt versions the fist gen are weaker then the 2nd gen 8.5" coprerate I think the nova int the mid 70 has the 8.5 10 bolt of the 1st gen dimentions it could be a economical choice. here is a link for more info on rear ends http://www.hotrod.com/techarticles/axle_rear_end_guide/
Griff is right about the later model 8.5" 10 bolt and they will handle most applications that are for the street as well as low HP strip applications. I don't thick anyone could give youa number on that as there are too many situations that dictate whether a part will hold up or not.
I believe that most of the people that you are talking to about switching iver to a 12 bolt are telling you this for most ikely one main reason. If you're going to gut your 10 bolt, it will cost you "x" amount of $. If you're going to gut a 12 bolt, it will cost you "x" amount of $. Same amount either way. (give or take a few $) So for the extra $100-200 you will spend on the new housing, the benefits will be reaped.
I for one, will always agree with the masses on this one. Pay the $200 more for a junkyard 12bolt and use it. BTW to save those costs, you must find one that will bolt up with no mods to the tubes or housing.
RM
RM
ORIGINAL: skar
Ok new 12 bolt Strange, DTS, Currie,or Moser which one.?
Strange and Moser also have a very good reputation. They make a very good product too and will handle just about everything you throw at them. They are also a better cost alternative too but are also more into the mass production. IMO
DTS and Currie I cannot comment on as I don't know their product.
If cost is a factor, then I would chose Moser. They have a great customer reputation and are even well known in the racing end of things and their cost is resonable. They will work to get you what you ask for.
I will always suggest MW over anyone, but most people don't have that kind of budget and Moser will definately give you nearly the same quality for a lot less.
RM
