how much horsepower can 200r4 take
#21
i got my 200-4r from extreme automatics and will handle around 700hp and 600-650tq. you can get 200-4r's to handle alot of power but you have more power than i do as i only have around 500-550hp at crank. with your amount of power i'd go with a 4L80 from jake and they can be full manual without controller. you will need to shorten driveshaft and replace crossmember. if you wanna run a mechanical speedo you will also need the mechanical tailhousing for extra $400-500.
#23
yeah he sure does know his stuff,and those trannies are well worth what he charges alot of work in those trannies,and he takes pride in the work he does that there says alot and he stands behind everything he sells.
#24
I've heard good things about this company, but didn't see anything on their site about a 4L80E that would make it a 4L80 without a controller? Maybe I missed it when I looked around there. Even their transbrake 4L80E still uses electronics from what I could tell?
#25
if u click the link damon posted it says that half way down the page when the talk about the transbrake for 500 bucks u can get it either with having to use a controller or no controller required.
#26
here it is val from his website.
The new Jake's Performance 4L80E transbrake is here! We have designed an all new transbrake for the 4L80E. It does NOT require a deep pan like our competitor's unit. It can be setup as automatic with computer controlled or can be built as a full manual setup where no controller is required.
#28
ur welcome,that would probably make a sweet tranny for racing and the street but a little expensive unless i did one myself,then added the transbrake.what u think about the 4L80e val,is that a pretty tough tranny from the factory.like the 400 is,or needs lots of work to handle the power.
#29
I haven't had much experience with the newer 4L80E. All I know is what I read about them, and it's all good from what I hear. They've been compared equal to the old TH400, with electronics added. But even they aren't cheap in stock form, unless you get a good deal used.
#30
