here's the pics...bought the car...
Old 05-17-2008 | 02:05 PM
carguy_z28's Avatar
Default RE: here's the pics...bought the car...
thanks...apreciate it.
  #32
Old 05-17-2008 | 04:14 PM
Before I get all itchy from tire-envy, I have to ask if you actually measured yours, or are going just by the tire's numbers? The "295" dimension refers to the Section Width (295 mm) of the sidewalls of the tire, not the tread width. And my sidewalls roll down into the tread more so, as opposed to a more straight up and down sidewall.
And, if you already know this one, fine. Maybe somebody else doesn't...
295/50/15 breaks down as:
295 = cross-section width in millimeters
50 = aspect ratio-sidewall section height (from tread to rim) is 50% of the section width
15 = rim diameter
I'm not tryin to nit-pick, just want to make sense of the difference.
  #33
Old 05-17-2008 | 05:24 PM
SpecterGT260's Avatar
Ninja Administrator
ORIGINAL: carguy_z28
You have to remember tho, its not just the 295 part thats the width... its that with the ** series combined with the inches... IE... my vette has 295/35/19's on the back, and they are not as wide as these tires are...
i agree with 69. ive always been told the first number relates directly to width, and the 2nd number references wall hight as a percentage of width. so a 295/35 and a 295/50 have the same print, just different sidewall hights. maybe its the wheel spacer playing tricks....
  #34
Old 05-17-2008 | 05:26 PM
Ninja Administrator
scratch that. it IS the spacer. i checked out the pic again, they are big tires, but not as crazy-go-nuts wide as i had thought.
  #35
Old 05-17-2008 | 07:27 PM
carguy_z28's Avatar
  #36
Old 05-17-2008 | 07:29 PM
carguy_z28's Avatar
First pic, plastic tab is on sidewall 2 inches down on inside of tire... so just under 12 inches of tread, off ground, 13 with weight of car, Second pic, sidewall is 13 inches wide with no weight pushing them out, third pic, is my size 11 1/2 shoe next to tire...
  #37
Old 05-17-2008 | 07:40 PM
Ninja Administrator
ya, i thought u said 15 inches of rubber and i was like O_o
thats more reasonable. those do look like 295s in those pics. is there a reason for the spacer? personally id take it off unless you need it for clearance reasons
  #38
Old 05-17-2008 | 07:58 PM
74454bb's Avatar
May 2007 ROTM
I'm not sure I like it at all... the color..the bumpres, 74 had to be one of the worst years for the camaro... nope I don't see anything I like about it.
Ya know I'm full of it... beautiful.
  #39
Old 05-17-2008 | 08:02 PM
carguy_z28's Avatar
LOL nice 74454... hey what is the color or the car? Do you know the code by chance??
  #40
Old 05-17-2008 | 08:04 PM
carguy_z28's Avatar
ORIGINAL: SpecterGT260
The spacers are needed, There minimal anyways, it gives me just an 1/8th of an inch of clearance inside, before they start rubbing... I thought they were 15 inches... I was mistaken, but they are wider than 10 inches, I knew that, lol...
Quick Reply: here's the pics...bought the car...
