Help! No start!
New to the forum, looking for help. 78 Camaro cranking over just fine, but will not start. We had VERY old gas in it. Siphoned most of the gas out, put seafoam in and fresh premium gas, also used a ton of starter fluid, no luck. (Tried 15+ times so thinking I cleared bad gas out?) Where the line is from fuel pump saw a mediocre amount of fuel splashing up. Tried putting pedal to floor and pumping as well. 1 year since last start. Bells is her name, and I must save her or my hubby will make me get rid of her! Give it to me simple guys, as this is my first project car. Thanks so much for your time and help!
Bunch of reasons why an engine won't start besides bad gas. You could start by looking at these things.
Make sure you are getting a good spark.
Does the engine start with the starting fluid?
Choke working properly?
May want to replace fuel filter, and fuel filter in carb inlet (if it has one)
Fuel system and/or carb could be crudded up and not allowing enough fuel to pass.
Bad fuel pump.
Bad fuel pump.
Since you've tried starting fluid, I'd rule out fuel as a issue for now. If it had spark, then even a bad batch of gas wouldn't stop it from firing for a few seconds. It really sounds like it isn't getting any spark, so pull a plug wire and check that by putting a screwdriver in the end of the wire, and holding the shank of the screwdriver about 3/8" from a good ground.
If the engine doesn't give a spark, then check to see if the coil has 12v. power at the distributor cap. If it has power, then you've got either a bad coil, cap, or rotor. If the plug wires are good, I'd start with a new cap and rotor. I'd also take my coil and cap along to a chain store like Autozone, or others, who can check the coil to see if it's also bad or good.
AS BB427 suggested, if no start on starting fluid, other issues.
Since a '78, check power plug to HEI distributor labeled BATT.
The plug may have fallen out.
You could put a test light o the plug and turn ignition switch to IGN and check to see if test light, or meter if used shows power.
No power then maybe a blown fuse or mis-adjusted ign switch.
Question, have a short green wire coming out of the front passenger side of radiator, small black plug... (tried to upload picture but don't have time to figure out how.) Any guesses as to what is might be? And headed to the autopart's store for some diagnostic tools, any suggests on what you might consider a must have?
Sorry if you guys feel like you are talking to a moron, you are. My dad was smart enough to teach me some of the basics when I was very young, but he died early. I've forgotten most of it, and had to think twice about doing so much as removing the battery cables, afraid I'd be shocked. Stick with me here, I beg you.
