Headers install??$$$$$
Old Nov 22, 2012 | 01:12 PM
I'm too tight to pay for much labor. Even if it takes me all day to do what a shop can do in a couple hours, I'll still do it to save a buck and learn. I think if I was a rich guy, I'd still try to save $5 by doing it myself. Just can't get shed of that mindset of do it yourself thinking.
Old Nov 22, 2012 | 07:26 PM
B.M.'s Avatar
I'm just the opposite haha,if i could afford it,i would have someone else do every bit of work i have needed done,but since i dont have the money to cover labor on most things,i am forced to learn and do it myself.
Old Dec 4, 2012 | 09:47 PM
Jeepin's Avatar
Hey guys alright so my headers are installed now but now I can't get the bracket that goes on the power steering and a/c back on it won't fit so now I can't turn as easily!!! I don't have the a/c hooked on so is there a bracket I can use that will fit even if it doesn't have the part for the a/c????
Old Dec 5, 2012 | 04:29 AM
The piece should have came with the headers. If not measure the gap, from memory I'm thinking 1 1/4" - 1 1/2" then go pick up a 1/4" NPT pipe nipple that length from Lowes or where ever.
Old Dec 5, 2012 | 07:26 AM
B.M.'s Avatar
Yeah,thats what i did when i first installed my headers and it worked out perfect,and it's very cheap,only cost like $1 or so.Another option,which is alot more expensive,if your not going to hook your a/c back up,is to get a march power steering bracket,i just put one on last summer and they look great and mount to the block and water pump so the headers dont affect it,but they are a bit over $100.
Old Dec 5, 2012 | 09:03 AM
Edwardgp's Avatar
Get the nipple, fix the problem and let us know how it worked.
Old Dec 5, 2012 | 11:27 AM
Jeepin's Avatar
Where does the nipple connect to?? Any pics of how u guys did it??
Old Dec 6, 2012 | 02:57 AM
It is a spacer between the header and the bracket. You'll need a longer bolt too. Oh yeah, we're talking about the first header bolt.
Old Dec 6, 2012 | 10:15 AM
Just hold the bracket up where it clears the front tube, then measure the distance to the header flange and cut a spacer from the pipe nipple. Then get a bolt with that much extra length on it to put it all together.
Or if this is too complicated you could spend some money and get a universal chrome bracket and base from Summit for about $12. That's what I used for my gasser:
Old Feb 6, 2013 | 03:50 PM
  #20
ZL1CAMARO's Avatar
I need help also I don't understand the A-arm lower control arm mod do I grind some off where the headers contact? or what does this look like on yalls car?
