gas runs back right away?
Old Jul 4, 2012 | 10:59 AM
manslaughter299's Avatar
Default gas runs back right away?
So we put in a new fuel pump on the 350 and id start it and run it fine and drive for a good 10miles but when i stop and pop the hood, all the gas is running out of the filter right away and if i try to turn the key 3 mins later, i gotta pump the gas again. When we first put the pump in it held the gas but now it dosent. ideas?
I dont know if this is related to this or not but also after driving and warming the engine up when i turn it off, leave and come back to start it again it starts hard. the starter is cranking and everything and i tried pumping gas and holding throttle down a bit but its not an instant start. and when it does, it wont stay running very easily. when i back out of a parking spot, it will cut off. when i start it again and put in drive, it tries to cut off also. It didnt do this before the new pump. We also re-routed the gas line to the carb from the pump and it touches a heater hose and i heard it might be a problem with gas boiling or something? please help
This is the pump i have. its a 3 line. And if it is the pump, any suggestions for a new one?
Airtex 40777 - Mechanical Fuel Pump | O'Reilly Auto Parts
Old Jul 4, 2012 | 11:44 AM
For some reason the gas is running back through the bypass line and to the tank. The pump must not have anything to prevent back-flow. Was your old pump the same bypass style. And yes, the gas siphoning back would also be why you're having a difficult restart issue. I would move the fuel line away from the heater hose, but that's not why gas is running back and leaving you dry.
A simple fix would be to install one of these: Fuel Check Valve
Old Jul 4, 2012 | 03:05 PM
alright il try that out in the next few days and tell you how it goes. thanks.
Old Jul 5, 2012 | 09:26 AM
Do you have the lines connected to the correct ports on the fuel pump? Double check them.
Old Jul 5, 2012 | 11:59 AM
Yes because it's two slightly different size hoses
Old Jul 5, 2012 | 06:22 PM
If its a cheap parts store pump the diaphragm may be allowing the siphoning. If it has a slight tear it will pump but not hold pressure. I have super expensive race pumps do it.
1998camarossclone
May 11, 2013 11:05 AM
19IroczCamaro87
82-92 V8 Tech
Oct 16, 2011 06:41 PM
adirtypoostick
82-92 V8 Tech
15
Mar 1, 2009 08:15 PM
z28nate
Aug 4, 2007 01:34 PM
sewerrat
82-92 V8 Tech
Aug 15, 2005 03:17 PM
