Fuel line return
Old Apr 25, 2013 | 09:25 AM
fire43f's Avatar
Default Fuel line return
I am planning on replacing all fuel lines on my 81 Z28. I am doing this because I think my Holley is leaning out because of not enough fuel being delivered to the carb. Question is if I plug the fuel return line at the fuel tank will this effect fuel delivery? I do plan on replacing the pickup inside of the tank also so everything will be new. Is there any options for a single line sending unit? I did find one but it was the wrong year and wrong engine size.
Old Apr 25, 2013 | 04:09 PM
Having a return line is an enhancement over a single line setup, because it's easier on the pump, and having the fuel continuously moving and circulating can keep it cooler before it gets to the carb. Why do you want to do away with that?
Old Apr 25, 2013 | 06:32 PM
fire43f's Avatar
How do you hook up a return line on a Holley mechanical fuel pump? It has no connections for it at the pump
Old Apr 25, 2013 | 11:55 PM
You could install a return style fuel pressure regulator.
Old Apr 26, 2013 | 07:00 AM
fire43f's Avatar
OK that makes sence. Thanks for the info. I think I make it harder than it needs to be sometimes.
Old Apr 26, 2013 | 07:03 AM
Edwardgp's Avatar
You are just on the learning curve, you are not going to know everything.
manslaughter299
Jul 24, 2012 03:17 AM
91TealRS
Aug 31, 2011 08:35 PM
Tom071
70-81 V8 Tech
Aug 29, 2010 06:20 AM
craby
Jul 20, 2010 12:17 PM
350rs
Jun 19, 2007 10:12 PM
