Frame supports
Old Apr 6, 2021 | 11:36 AM
WayneJackson's Avatar
Default Frame supports
What does anyone recomend to install for the extra power from the engine so the frame stays solid i was wondering if the frame of a 48 year old car might need frame braces installed. Does anyone have any input on that subj
Old Apr 6, 2021 | 03:44 PM
Zspoiler's Avatar
It will stiffen up the front chassis and help in the handling of the car .Along with frame connectors.
Old Apr 6, 2021 | 06:00 PM
Default Frame stiffen
I'm Looking for something that will keep the frame from twisting as power is applied what is out there and what is recommended by anyone that has used them?
Old Apr 6, 2021 | 08:05 PM
Subframe connectors,there are several styles available,I have bolt in connectors in my 2001 SS.
Some bolt in others weld in,some much sturdier than others,what you want depends on how much power you are planning to put to the test.
They start at less than $200.
https://www.jegs.com/i/Competition+E...xoCoq0QAvD_BwE
https://danaport.com/products/hotchk...gn=sag_organic
Jacouncil3
Mar 22, 2025 09:25 PM
blee62
Oct 6, 2010 04:54 AM
77nomad
Nov 21, 2009 11:28 AM
2nd gen year 78'
Sep 2, 2009 07:48 PM
z28
Mar 10, 2006 05:02 PM
