Flywheel 79 camaro help
Old Mar 12, 2012 | 05:08 PM
justinw23453's Avatar
Default Flywheel 79 camaro help
I hear a rattling sound from my car and I hear it coming from my transmission. I take off my inspection plate and find a bolt. It looks like it came from my fly wheel. I could be wrong but i think it might have to do with my flywheel or torque converter. whenever my car is warm there is almost no rattling in park, but when i put it in reverse or drive it rattles like crazy. Could someone please tell me if i need to lift my engine up to get to my transmission? Also could it be something else? thank you.
Old Mar 12, 2012 | 08:41 PM
5time F's Avatar
OK I doubt this is good... you have 3 or 4 Torque converter bolts and 5(?) 6(?) flywheel bolts.... If it is a Torque converter bolt you might get lucky and just re install it.... if it is a flywheel bolt you have to drop the tranny and inspect the flywheel (the true term for an automatic is Flex plate) for cracks... I would think you have a cracked Flex plate... not hard to replace in the grand scale of the universe but you do get to yank the Tranny our to do it. A talented person who has done it a few times might get it done in a couple of hours...
Old Mar 13, 2012 | 08:38 PM
larrry_anthony's Avatar
I would definately check the converter bolts first. There should be 3. You can check these by removing the dust cover and having someone just bump the engine over.
mab6680
Apr 20, 2011 05:40 AM
blowncamaro
Jan 5, 2010 09:44 AM
glue maker
Jun 5, 2009 01:53 PM
greenarrow
Apr 18, 2009 07:16 PM
nabisco
82-92 V8 Tech
Nov 15, 2008 04:12 PM
