Driveshaft question
Can someone please tell me the length of the stock drive shaft with the turbo 350. Thanks
Originally Posted by BoSoxFanSims
(Post 450605)
Sounds right. I think there 45.5 for a 700r4.
I just re-checked my measurement. It's 50
'95 3.4 Drive Shaft Interchangeable??
Originally Posted by rosky69
(Post 451035)
My 2 pc measures 41.75 center-to-center (off a little since measured installed with tape bowing around carrier bearing). This forum repeatedly states "any 3rd or 4th generation made to fit 700R4/4L60 will work". I must be missing something as there is at least 8" diff (~42" to 50")??? Educate Me PLEASE! |
"I'm in the process of changing over from 2pc to 1pc, preferrably alum.
My 2 pc measures 41.75 center-to-center (off a little since measured installed with tape bowing around carrier bearing). This forum repeatedly states "any 3rd or 4th generation made to fit 700R4/4L60 will work". I must be missing something as there is at least 8" diff (~42" to 50")??? Educate Me PLEASE!" I'm confused now. Do you own a 2nd Gen Camaro? (1970-81) If so, then how did it ever have a two piece driveline? |
Originally Posted by MichaelAW
(Post 561580)
My 2 pc measures 41.75 center-to-center (off a little since measured installed with tape bowing around carrier bearing). This forum repeatedly states "any 3rd or 4th generation made to fit 700R4/4L60 will work". I must be missing something as there is at least 8" diff (~42" to 50")??? Educate Me PLEASE! But to answer your question again, yes any 3rd gen (700R4 vintage/length) or 4th gen driveshaft will work. |
