decoding a 10 bolt rear end on a 1969
HI, i was wandering if anyone could give me some help on how to decode my rearend and axle. I am currently cleaning them for show purposes and i am in search for the numbers on the rear end. I found a set of numbers to the left of the casing (if your looking under the car from the back end). But i have not found any more numbers. Where are the location points for all the numbers at? I also am wandering what type of paint ypu sue to paint your rear end. Any help is appreciated
1969 chevrolet camaro 307 powerglide/10 bolt
RE: decoding a 10 bolt rear end on a 1969
Well Nastyz28.com should help you decode it. As far as other locations I'm not quite sure on a 69. Are you looking for a black or a cast look? Cast Blast paint would be the way to go for a cast iron look. From National Parts Depot (http://www.npdlink.com) part number AP-CG $4.95 Or if you're looking for a grey, there is Shock Gray Paint C-116-S $5.95, If you're looking for a permanent rust inhibitor, there is no replacement for POR 15, but that might cover the numbers. I personally like using Roll cage and epoxy paint. I don't have a part number, but I always use VHT.
