control arm shims
Old Oct 30, 2006 | 11:07 PM
mccomas's Avatar
Default control arm shims
While changing to disc, I decided to pull my “A” arms and replace the bushings and ball joints. I have about a 1/4 inch of shims on each of the two bolts on both control arms. This seams like a lot of shims. Is it? Also, once I get everything put back together, I am going to need an alignment. I have not seen these shims in any of my catalogs. Where can a get them? I would like to get a verity –it looks like they come in 1/16 of an inch increments. Thanks…
67...
Old Oct 30, 2006 | 11:18 PM
shnormo's Avatar
Default RE: control arm shims
They actually have different thicknesses. A body shop would actually carry them (believe it or not). The alignment shop should have a supply too. They do have a lot of shims for a more adjustment parameters. I personally have 4 on each bolt.
Old Oct 31, 2006 | 09:29 PM
MadMikeZ28's Avatar
Just put the shims back where they came out and get an alignment. Or if you need spares look where your fender bolts to the body. You might find a few there.
Mac 7
2010+ V6 Tech
Sep 13, 2011 03:22 PM
tnomi
Jul 6, 2011 08:47 AM
cadmanof50s
Dec 22, 2010 01:33 PM
Combat_Chuck
Apr 19, 2008 11:03 AM
83_camaro
Dec 13, 2006 10:28 PM
