Clutch Linkage
I am not sure what the book says but I used to pull the motor mount bolt and jack the motor up. Set the bar between the two pivot ***** and let the motor back down. I think you may be able to tighen the frame side ball while you are installing it. Most of the times I put mine in I want putting the motor in so my way was easier.
If you want a full proceedure you should get a GM manual.
