Can some one help
Can some one help
hi All I am working on a 77 camaro the engine is new 410Hp and about 490 Tq i am haveing troble geting my carb right. it is ok just around town but if i get on it hard it will not burnout and around 5500 it will lean all the way out i have raised the fuel level and it helped out. i have went up 2 jets #67s bit it has a metering block for the back bowl. I am looking into geting a new carb. (demon Jr 625 is what i have now) but would like some help with picking one out. next winter i am going to put twin turbos on it with 10-12 lb boost so i would like to get something i could use with that. can someone help me out with what would be good. thanks
RE: Can some one help
Ok Ok, I can't stand it, you need to get your carburetor modified, or buy a new one.
You need what is known as a "blow through" carb.
If this forum were worth a crap, someone who knew about this would have come along and given you a link to the necessary modifications.
Here, http://www.hangar18fabrication.com/blowthru.
Brought to you from your friendly Moparts Forum.
625 cfm is too small for a stongly modded 350. your motor is starving for air at higher rpms. you need to upgrade to a 650 or 700 cfm. i currently run a 600 cfm edelbrock because i got it from someone i knew and it was cheap. the motor starves for air at high rpm, the carburetor doesnt necessarily lean out, it jsut cant spit out as much air and fuel as the motor desires. its jsut a temporary one until i can afford a barry grant 650 or 700. if you want to stick to barry grant, get one with mechanicle secondaries. and either 650 or 700cfm. you hjave a high power motor, so i would prefer the 700cfm. i like the speed demons but unless you can sacrafice having a choke, stick to a road demom.
