can anyone recongnize this engine?
Old Sep 22, 2006 | 11:28 AM
stunna's Avatar
Default can anyone recongnize this engine?
Says its a 350 v8, but I am trying to figure what the specifications are.
Swapped into a 1980 Camaro ttop not original.
Old Sep 22, 2006 | 11:53 AM
Blade's Avatar
June 2007 ROTM
Default RE: can anyone recongnize this engine?
its def a small block. but what u wanna find is the numbers on the block. they are on the back of the motor on a plate near the oil filter. if not there they are on the front near the water pump its gonna be hard to find due to the grease.
Old Sep 22, 2006 | 01:52 PM
81CanuckZ's Avatar
It's most likely a 350 or 305. Probably a 350 as they're so easy to find. You can also tell if you take the valve covers off there should be a number there that tells you if has 305 or 350 heads. That will be easier to find because it should only be covered in oil...not grease. Good luck.
Old Sep 22, 2006 | 02:03 PM
Blade's Avatar
June 2007 ROTM
ORIGINAL: 81CanuckZ
do that first and if u can not find the answer look on the block.
Old Sep 23, 2006 | 05:27 PM
stunna's Avatar
its an ebay car. I am trying to decide if I want to buy it or not based on the engine.
Old Sep 23, 2006 | 06:11 PM
1969 SS's Avatar
forget it then.
just from that one pic it looks Mickey Moused at best. the rest of the car can only be worst and it is probably a nightmare. if the engine bay is that bad, then YOU KNOW the t-tops leak like waterfalls.
for that matter, someone could have put a 307 in there at one point just for a cheap runner
Old Sep 23, 2006 | 07:22 PM
81CanuckZ's Avatar
The 307 is a dog. It's not a great engine. Don't buy it if the person who owns it doesn't even know what kind of engine is in it. That spells disaster.
Old Sep 23, 2006 | 07:36 PM
stunna's Avatar
its only $1000 though, and is rust free. Can anyone verify thats its a 350 from those looks?
Old Sep 23, 2006 | 07:57 PM
Blade's Avatar
June 2007 ROTM
no u have to run the numbers.
Old Sep 23, 2006 | 09:48 PM
81CanuckZ's Avatar
Maybe on one side of the car there is no rust. Have you seen the frame, under the trunk, other possible and easily rusted out areas? If it seems too good to be true it pobably is.
