Camaro Rearend?
Old Aug 17, 2010 | 03:35 PM
CaMaRo55's Avatar
Default Camaro Rearend?
i have a 1973 camaro LT and want to put a different rearend in it to replace the stock 10 bolt. does anyone know if a newer camaro rearend will fit on my car? probably a 93-00? if anyone has some tips or has done this the help would be greatly appreciated.
Old Aug 17, 2010 | 05:25 PM
Third and fourth gens have a torque arm rear suspension. In short no, they are coil spring. Beef up the 10 bolt. Parts aren't too expensive. Do a google search and there are tons of build up articles on 10 bolts. Stay away from s10 rears. Unless you can score a 12 bolt from an early second or have one built, be it Ford 9", 10/12 bolt, or Dana 60. (prices are around 3grand ready to go)
And welcome. Very nice people here.
Old Aug 18, 2010 | 03:31 PM
kyphur's Avatar
Newer 10 bolts are also 7.5 inch ring gears and break easily under torque and power. The older ones in the second gens are 8.5 (or 8.2 if you have certain 70 models) which have the same pinion thickness as a 12 bolt rear.
Old Aug 18, 2010 | 05:10 PM
79camz28's Avatar
I'm in the process of installing this set i picked up off of ebay..http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Im also putting in rear outter axel seals and bearings..
mitchecw
Apr 19, 2012 08:55 PM
Jeepin
Feb 11, 2012 05:35 PM
HD123
Sep 29, 2011 05:49 PM
Manchester
Oct 28, 2008 05:24 PM
scottlee1
Jan 28, 2008 11:39 AM
