Cam with gear
Old Feb 12, 2010 | 10:04 AM
tbl76camaro's Avatar
Default Cam with gear
Which gear ratio would be better with the Voodoo 60102 cam? 3.23 or 3.42? I don't want my car to be revving too high while cruising. About what RPM would it be at 60mph with each gear?
Look in sig for specs.
Old Feb 12, 2010 | 01:34 PM
That's a pretty nice cam, and one that will make a nice street cam for your car; (Duration 262/268, Lift .468/.489, ) Either gear range will work, and at 60 I doubt you'll be much over 2,200 unless you have extremely low profile tires using the 3:42 gears.
I think you'd be able to even run a little lower and not be revving to much down the highway, but 3:23 would be a little too doggy out of the hole.
Old Feb 12, 2010 | 10:35 PM
Thanks, I'll probably be getting the 3.42 gear just to save a little gas, instead of going smaller on the gear. Is there any specific brand you would suggest?
Old Feb 12, 2010 | 11:22 PM
Can't say as I've purchased enough to call out any as the best. Richmond has a great reputation, but I think you can save about $50 by buying the Summit brand that's made by Richmond.
The biggest cost will be having them installed. The gears run around $150-$250, and installation will run about the same.
You might consider finding a good used rearend that's got the gear ratio you want. Then swap rearends and sell your old one to recoup some funds.
Old Feb 13, 2010 | 12:09 PM
Whats an estimate of pulling a rearend out of a junkyard?
Old Feb 13, 2010 | 12:25 PM
I think you'll find one for about the same price as a set of gears. Just be sure to pull the cover and do a visual inspection first. Might also check Craigslist too. I've seen them on CL for under $100 every so often. What ratio do you have now?
Old Feb 13, 2010 | 03:20 PM
Yeah, I've checked craigslist, but haven't found one yet. I have a 2.73 non-posi right now. Suggestions on what to pull one out of?
Old Feb 13, 2010 | 04:04 PM
A 2nd gen Camaro or Firebird. Anything else will need mods to work. Not sure about the width on the later 3rd & 4th gens, but if the width is right, they might also work by welding mounts from a 2nd gen on the axle.
Just keep checking Craigslist, as they do show around here about once a week. Saw one today from a 79 Firebird for $150.
Old Feb 13, 2010 | 06:17 PM
Sounds like a pretty good price, if only I didn't live so far away. Is it posi, cause thats what I need. But, haven't got the cam yet. I've got the money for everything, but just haven't bought anything. Which would make a bigger acceleration difference, the 3.42 gear or the 60102 cam? I've just got the time to do one thing at a time right now.
Old Feb 13, 2010 | 08:08 PM
Pablo63's Avatar
Banned
From: Raised in Tilton NH now residing in Kings Mountain KY
Here's a great article I put in my fave's a while ago. Good info.
http://www.chevyhiperformance.com/te...all/index.html
