Calling out member--RedRocket72
Old Nov 23, 2009 | 09:03 PM
ROWDYROB's Avatar
Default Calling out member--RedRocket72
ok--this guy is a member here (RedRocket72) and here is his camaro--i have got to know the size and make of these tires and rims and the backspacing--this is the exact setup that i have been looking for,i have browsed through hundreds of photos and ran across this one and now i cant get ahold of this guy to find out--man this is killing me to know--lol
Old Nov 23, 2009 | 09:41 PM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
You tried sending him a PM?
Old Nov 23, 2009 | 10:06 PM
A simple advanced search found a post by RedRocket72 telling all about his tire and wheel combo. Check here, the 4th post down:
https://camaroforums.com/forum/70-81-v8-tech-47/tire-size-72-camaro-26345/
Old Nov 23, 2009 | 10:29 PM
ROWDYROB's Avatar
hey--thanks,i'm new on here and didnt find that---but still leaves me wondering what width rims?
Old Nov 23, 2009 | 11:02 PM
I think if you take the picture and tire info to your local tire store they can easily tell you what width the rims most likely are. With tires he says are 13" wide in the rear, I bet his rims are 10". If you measure from the face of your drum to the closest obstruction you can get the depth, and figure what backspacing you need. Fronts still look like 7" to me.
Old Nov 23, 2009 | 11:38 PM
ROWDYROB's Avatar
I may try that if i dont get a response from the pm i sent or more info--mine now are 14 inch high,just wondering if i should go to 17 or 16?--i also have airshocks on back and should be able to raise it up keep from scrubbing the fender well if it tries to scrub there--thanks
Old Nov 24, 2009 | 08:05 PM
I've never been a fan of the really large diameter rims, but I have to admit they look really nice on that Camaro. I think if I was doing it I'd use the 17" he has and the same tire. It has a lot better stance than most the big wheeled cars I've seen.
Old Nov 24, 2009 | 08:29 PM
ROWDYROB's Avatar
yea--i always hated to see big rims on a old muscle car--but i do like these--just wondering about going 16inch?--and i still am trying to find out the rim width and offset----thanks
Old Nov 26, 2009 | 10:00 AM
BBRSZ's Avatar
you can put an 17x11" TT2 rim on the back w/ a 6" backspacing.
But you have to roll the fender lips.
Then you can put 315 35 17 tires/
Attached Thumbnails Calling out member--RedRocket72-bbrsz10wb.jpg   Calling out member--RedRocket72-bbrsz...jpg   Calling out member--RedRocket72-rsz.jpg
Old Nov 26, 2009 | 09:34 PM
ROWDYROB's Avatar
THANKS--were are having to roll the lip,is it hitting on the sides or top?--i have air shocks and could probably raise it some if it was hitting on the top--and also are you saying 6'' for the backspacing or the offset?--and how about your fronts--what is the width and offset on those?--hate to ask so many questions,but i dont want to get stuck with the wrong rims---thanks
