A/C delete?
so, pros and cons to removing the huge a/c box on my firewall in the engine bay? i dont have a compressor and prob wont be using the a/c anyway. is it that easy to just remove the parts from the firewall? would the heat still work ok?
if you want heat you gotta get or make a heater box. its much smaller than the A/C one
1 Attachment(s)
You can buy a conversion box that deletes the suitcase for about 100-150 bucks. I had one until I smoothed my firewall. I'll sell it for 75. Its still new.
Attachment 21660 |
Originally Posted by 77nomad
(Post 601569)
http://i1011.photobucket.com/albums/...omad/035-1.jpg |
1 Attachment(s)
The box like mentioned above,makes a huge difference in appearance and room under the hood,plus you can keep the heat with them.All you have to do is move the blower motor on to the new box,and then move the 2 electrical parts,1 is the resistor,i forget what the other is called,but that about it.Here is a pic of mine installed so you can see how much more room and how much better they look than that huge a/c box.I busted my heater core trying to get the hoses off though,so if you do this just take it easy on the hoses,i got in a rush and bent the tube which caused a leak.
Attachment 21628 |
i might take you up on that 77nomad, i'm on a lil bit of a budget, trying to sell some old things/parts to make up some cash, ill get back to you, thanks
Don't forget the fun part,about removing the wheelwell!
If you ever take the box off the firewall to replace the core (and you aren't worried about keeping things OEM) you should cut the box in half so the core half can be removed easily in the future. I modified mine this way after the first heater core episode and I swore I'd never do that again. Simply cut it before I reinstalled it, then tack welded a piece of sheetmetal on the core half that overlaps the blower half.
Took me all of less than 1 hour to replace my heater core last time! |
Originally Posted by mike6208
(Post 601660)
I learned long ago.. If I pull a motor... replace the core. Pull the motor with A/C replace spark plug #8 too!!!! LOL!
