broken door latch
broken door latch
door wont open
ok, so the door handles inside and out work, the bars are moving the latch
However the latch wont release
I have tried using a screw driver to phisically move the latch mechanism but all to no avail
Im certain U need a new latch mechanism $60 from summit
Problem is how do I get the door open?
Do I have to pull the fender then the hinges?
its a 71
its a 71
RE: broken door latch
because the door pannel is off and I can see it
all linkage is working fine
the door latch just isnt releasing from the striker
It a safety precaution from GM
But that doesn't help me get the door open to replace the latch
oh, if you have the door panel off, just go to the nearest bodyshop and I bet they'll pop it openfor you for free. that will make it easier. just make sure you disconnect all the rods inside first to release any added stress on the latch
