brake power booster
Old Jun 13, 2011 | 09:49 AM
typeomang's Avatar
Default brake power booster
Does anyone have the diagram for a 1980 v8 automatic, on how to remove this. I believe the bolts are just on the firewall, is this correct?........1SG
Old Jun 13, 2011 | 09:55 AM
Yep, you remove the bolts behind the booster, and disconnect the crossbolt at the brake pedal. Then the brake lines and it pulls right out. Those bolts behind are a booger to get at!
Old Jun 13, 2011 | 10:36 AM
Ratchet wrenches are your best friend here. The flat ones not the reversable ones.
Old Jun 13, 2011 | 11:30 AM
Be careful with rachet wrenches to switch back and forth, as if you back off too far it ends up caught in there as the nut backs off!
Old Jun 13, 2011 | 02:28 PM
I have room. I know what your talking about though. I haven't been totally stuck YET. A couple times at work with a regular ratchet I did get screwed. Spent an hour building a tool to reach inside a machine and flip the reverse. LOL Boss was like WTF are you doing on a 35 min job.
Old Jun 13, 2011 | 02:46 PM
typeomang's Avatar
I still have a couple of questions, Is it a stud that has a bolt attached that you take it out in the engine bay right by the firewall or are the nuts under the dash, and anyone have any idea of the size?........1SG
Old Jun 13, 2011 | 02:55 PM
They're studs. The nuts (4) are in the engine bay side. 9/16" I think. Just takr the nuts off and disconnect the lines and the rod to the pedal. The studs will stay put.
Old Jun 14, 2011 | 02:00 AM
JmeZ28's Avatar
yeah they are 9/14 or a 14mm. You could first unbolt the 2 nuts from master cylinder from the brake booster and slid if forward. and just let it hang out. it's what I do anytime I'm just replacing the booster. this way you don't have to waste time bleeding the master and brakes.
iphone430.jpg?t=1302484608
here what your up against
here is the rod you have have to disconect from the inside.
Chevynutz
Mar 25, 2012 12:06 PM
exlimey
Feb 1, 2012 04:23 AM
sprtplt
Aug 8, 2011 06:33 AM
GLENN M
82-92 V8 Tech
Mar 1, 2011 02:25 AM
Dark Syde
Jan 20, 2011 10:43 PM
