Best Lowering springs?
Old Mar 5, 2011 | 02:33 PM
78maro's Avatar
Default Best Lowering springs?
Hey everyone I really want to lower my 78 camaro does ayone one know where I can get the lowering springs to do this?
Old Mar 5, 2011 | 03:33 PM
jason7504's Avatar
i would highly recommend talking to Dave at Pro-touring f-body or Keith at Custom Works. great products and service!
http://www.customworksproducts.com/7222.html
http://www.pro-touringf-body.com/
Old Mar 5, 2011 | 06:05 PM
78maro's Avatar
Thanks alot i will def do that monday
Old Mar 6, 2011 | 10:06 PM
oreocreaming's Avatar
why not just do lowering spindles? keep the factory ride and all.
Old Mar 6, 2011 | 11:53 PM
78maro's Avatar
How much would that lower my car? and how much does that run?
Old Mar 7, 2011 | 12:01 AM
2" drop spindle and 250-310 you can get them from classic industries and I'm sure for less on eba..
Old Mar 7, 2011 | 12:51 AM
jason7504's Avatar
the springs are cheaper and usually you need stiffer springs to prevent bottoming out if you lower the car. drop spindles can also cause steering issues: http://www.nastyz28.com/forum/showthread.php?t=115255
Old Mar 7, 2011 | 03:10 AM
cheaper doesn't mean better. Things can't always be about saving a few dimes. And no need for a stiffer spring, the bump stops wil andle that. You4 have to hit a dip pretty ard to bottom out depending on what size tire/wheel combo your going wit.
Old Mar 7, 2011 | 08:27 AM
Bump stops shouldn't be used too much. Best to go with a slightly stiffer/shorter spring. Plus you'll have to go that route in the rear, as lowering blocks are crap.
Old Mar 7, 2011 | 09:13 AM
78maro's Avatar
I have been doing a bit of research and it seems like Springs are the most common and recomended has any one ever used spindle or springs to lower their car??
