ANYBODY know were to get rear differential cover??
to be more specific--one of those cast aluminum ones to fit a 10bolt 77 camaro--i can find the cheap chrome ones everywere,but those just rust up in no time---thanks
Not sure either, but if you pull the cover you can measure. Or you can look and see if the cast housing has the square ears on the bottom edge by the cover. If it has the two square ears that show from behind, then it's an 8.5"
If you look at this old picture you can see the little ears at the bottom edge of each side.
![Name: cam16.jpg
Size: 71.7 KB](https://camaroforums.com/forum/attachments/70-81-general-12/37019d1501326085-anybody-know-were-get-rear-differential-cover-cam16.jpg)
My rearend is from a 79 Trans Am, but I think the 77 Camaro was also a 8.5".
![Name: cam16.jpg
pobasturd
10-11-2012 09:36 AM
